I have a Holley "red" fuel pump (12-801-1) and need to know if I can mount it upside down. I bought it rebuilt and have no instructions.
Right side up it it would work correctly if the fuel line is on the inside of the driver's side rail, but my fuel line is installed on the inside of the passenger side rail. In order for the flow to go the right way I'll either need to flip it upside down or route some more fuel line all funky.
The reason I ask is that my brother thought he remembered hearing of someone running it upside down and it overheating. I thought this might occur if the bearings in the motor are made for it to only operate right side up.
Also, do I only need to run a rubber mount between the pump and the frame, or should I put some rubber bushings / washers between the bolt heads and the fuel pump mount?
Thanks as always!
Thanks as always!
