Hotrodders Bulletin Board
#1
fuel pump vapor line
hey guys,i bought a fuel pump for my 87 caprice 5.7litre 350.it's a holly street-performance mechinical pump 80 gph.problem is there is no vapor line fittings on new pump.what do i do with line comming from fuel tank???????????holly pump#12-834 thanks JOE.
#2
How many rubber lines do you have? One or two?
If one, it should be a 3/8" "inlet" hose. If you have a second line, it's a fuel return line and is usually 1/4". It returns unused fuel back to the tank and helps keep the pump cool and helps prevent vapor lock. If you have 2 rubber hoses on the car but only one pipe on the pump, you got the wrong pump. The threaded fitting goes to the carb.
Always on the look out for cheap Nike shoes! |
#3
fuel pump
every aftermarket pump i've seen only has an inlet and outlet no vapor line.
#4
Maybe I'm not understanding your question.
That pump has two threaded holes for your fuel lines. One "in" from the tank, and one "out" to the carb. Again, does your car have TWO rubber hoses that run back towards the tank? If so, you have the wrong pump. You will need a "three line pump", inlet, outlet to carb, and fuel return line. Also, according to theHolley web site , that pump is preset at 7.5 pounds of pressure. If you are running a Qjet carb, it will probably be too much pressure and cause immediate flooding or at least run pretty rich. Qjets don't need more than 4-5.5 pounds.
#5
yes i do have two rubber lines one fuel and one vapor line and one to carb.thanks for info on q-jet i'll wait till i put my holly carb on it's a 4150 street avenger 670cfm and i will look for the correct pump.thanks for the info this site is very helpfull.ps know anyone who needs afuel pump ha ha.thanks JOE.
#6
Glad to help. (My wife has an 86 305 4bbl caprice)
Check out Napa or any good parts store. You should be able to find a NEW Airtex or similar pump for about 25 bucks that will be more Qjet friendly and have the correct hoses for your car.
#7
differential mess
back to my other problem.when i changed my differential cover the other day i was supprised to find pcs of a gear and what looks like pcs of carriers guts.i was talking to a friend who is up on cars and he said that maybe they are leftover pcs when a prior repair was made that maybe pcs were stuck in housing and pushed out when reassembled.it's an ex police car 5.7litre 350 vin "6" previous owner has no records of differential work i have all service records.could this be possible i have no noise from rear.
#8
Wow, finding parts in the diff is never good! LOL I think its time to pull the over again and have a real good look at all the parts. If it was from a previous "fix", someone did a crappy job of cleaning out the housing and tubes. Not to mention that crap floating around in the oil and possibly taking out the pinion and carrier bearings and pitting the ring and pinion. Look it over real good!
#9
good idea i'am going to take off cover tomorrow and check everything out real closely.i just had $1600.00 worth of transmission work done and i'am dieing to do a burnout run but am afraid of blowing up rear and ruining the transmission.thanks for info wish me luck JOE.
#10
After you've fished out all the metal that you can find (might use a telescoping magnet to reach down the tubes some) you can mount a magnet to the inside of the cover like some diffs come from the OM with.
Back to top |
Similar Threads for: "fuel pump vapor line"
| acceleration flat spot in carb. | corvettetonybone | Engine | 13 | 05-04-2009 03:49 PM |
| Holley Electric Fuel Pump Woes | streetrodderbn | Engine | 12 | 02-12-2008 08:38 AM |
| 93 Plymouth Acclaim fuel pump relay | 78 monte | Electrical | 14 | 04-19-2007 03:09 PM |
| Electric fuel pump bad or not? | HotRodMan | Electrical | 4 | 09-10-2005 09:47 PM |
| Ford 1 and 2 piece fuel pump eccentrics | lluciano77 | Engine | 17 | 10-09-2004 10:58 PM |
