fuel pump wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 09:20 PM
fuel pump wiring
wondering why the fuel pump hot wire flashes instead of a even current. and were the fuel pump relay is or were its located... the vehicle is a 1988 ford f-250 with a 460 automatic. its not fuel injected its run with a holley performer carb. dual tank and the problem is coming from the front tank. nothing else is modified other than the carb. any information or websites to find more about this problem would be great thanks.
Old 02-01-2010, 06:21 PM
Is it possible for you to disconnect the pump and put a volt meter(test lights can blink depending on connectivity to wire) on the connector with truck in the start position to see if the voltage fluctuates without being hooked up to the pump? Maybe the pump is failing..
Old 02-01-2010, 10:55 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
What color is the wire your checking? PK/BK is usually the color wire at the pump. Are you accidently testing the fuel level sender wire?
electric fuel pump question sexypizzaman Engine 26 05-19-2015 07:13 AM
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
E85 105octane pump gas Race Fuel Rob_E85 Engine 46 11-22-2007 12:55 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
fuel pump wiring 68bird Electrical 4 06-17-2004 10:25 AM
