-   -   fuel pumps flow rate ? (http://www.hotrodders.com/forum/fuel-pumps-flow-rate-232281.html)
ALLANB 04-27-2013 03:06 PM
hello , i have a 383 stroker with a edlebrock 750 carb. is the mechanical pump on the engine going to be good enough ? or do i need to go to a electric pump
68NovaSS 04-27-2013 06:01 PM
Depends on a lot of other factors, cam, rpm operating range, etc. What's the flow rate for the pump you have now? Do a Google and local search here on this site for flow rates, there are formulas to calculate fuel requirements.
thinwhiteduke 04-27-2013 08:01 PM
Check out this one.
http://www.summitracing.com/parts/ed...make/chevrolet
I haven't sucked mine dry yet!
Supports 600 HP , 110 gph , 6 psi. No need for regulator.
Duke
