fuel pumps flow rate ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2013, 03:06 PM
hello , i have a 383 stroker with a edlebrock 750 carb. is the mechanical pump on the engine going to be good enough ? or do i need to go to a electric pump
Old 04-27-2013, 06:01 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Depends on a lot of other factors, cam, rpm operating range, etc. What's the flow rate for the pump you have now? Do a Google and local search here on this site for flow rates, there are formulas to calculate fuel requirements.
Semper Fi
Old 04-27-2013, 08:01 PM
thinwhiteduke's Avatar
Living In The Past
Check out this one.
http://www.summitracing.com/parts/ed...make/chevrolet
I haven't sucked mine dry yet!
Supports 600 HP , 110 gph , 6 psi. No need for regulator.
Duke
6x D port head Flow Rate? beertracker Engine 5 09-16-2010 05:41 PM
Question on electric fuel pumps and fuel cells. eric32 Hotrodding Basics 14 05-11-2009 07:53 PM
Bosch injetor flow rate NorthStar Engine 0 12-17-2008 01:00 AM
fuel flow rate for stromberg 97s hemi gaz Engine 1 04-14-2005 10:13 AM
Flow Rate Data for '487' heads? pgtr Engine 3 09-14-2004 01:20 PM
