Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 01-08-2007, 12:31 PM
428ho 428ho is offline
Fuel pumps and returns
Ok, I just got back from my local supplier. He's a restorer/builder as well. Been doing this stuff 40+ years.
I was asking him about how to put a return line in my system as it only had a single 5/16 supply line and vented cap on the tank. I changed to a 3/8" pick up and line but was thinking of changing the pick up to one that has a 1/4" vent line and using it as the return.
I'm running an electric pusher pump feeding a mechanical on the engine with two 650 cfm Carter's but I was going to put a bypass regualtor in the system. between the pumps.
Since I'm running an electric pusher pump I was worried about over pressure, deadheading and overheating the pump, hence the bypass regulator and return line. He's seen the 1/4" vent line used as the return since mine has a vented cap but since it dumps right over top of the pick up he's seen it aggitate the fuel causing air in the fuel pick up system.
Solution is to weld a bushing in the tank away from the pick up. Not what I wanted to hear. Other options are an on demand fuel pump but I already have the pumps, or just let it run and take my chances. He doesn't think it will burn out and I do run a mechanical pump on the engine as well.
I do need a regulator somewhere in the system but it does it need to be a bypass type?
Opinions?
Old 01-08-2007, 08:27 PM
jimfulco jimfulco is offline
re: Fuel pumps and returns
Any way to angle the tank end of the return tube so it shoots away from the intake?
Old 01-08-2007, 08:39 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Just a thought here---not knowing what car you have.
But most cars have a vent near the fill pipe of the tank.
Has anyone thought of tapping into the the fill pipe vent???
No aeriation (spelling??) of the fuel if it is being reintroduced to the tank at the fill area.
Most of these vents are 1/2 to 3/4, should not be too hard to tap into it.
Not sure how it would affect the filling of the tank at the gas station though.
I used a 78 Bronco tank in the 59----with a 85 sender and internal pump (sender was not usable so a SW sender was installed in the tank top vent)
I also use a bypass regulator (located in the return line just before the tank).
Thinking ahead---in case I go fuel injection
Check to see if any other (newer) sender would work in the tank, that already has the return.
Bryan
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
