fuel regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 06:44 PM
fuel regulator
i put a 600 cfm holley on my 403 olds and i have a push style electric fuel pump 4-9 psi with a holley 3way fuel regulator 4.5-9 psi. The fuel regulator has a input on the bottom and a output on each side.
I want to know what psi should i run.
Do i run 1 output to the carb and the other output as a return.
Old 08-12-2012, 07:12 PM
Richiehd's Avatar
JS-70
That regulater is probably designed for a dual feed carb. Just block the one outlet with a proper fitting if you have a single feed. Run 4-5 psi fuel pressure.
Old 08-12-2012, 07:59 PM
So i cant use the other outlet as a return
Old 08-13-2012, 07:11 AM
Coppertop's Avatar
You need to keep the fuel pressure constant through the one outlet to feed the carb. Using the other outlet for a fuel return line would just bleed 4-5 lbs of pressure back into the tank. Fuel return lines are really only needed for fuel injection. At least that what I use them for.
Old 08-13-2012, 11:05 AM
i just used the other outlet for the psi gauge.
Old 08-13-2012, 02:06 PM
Richiehd's Avatar
JS-70
Perfect!...
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 18 10-25-2009 01:51 PM
fuel regulator madgraphix Engine 3 07-05-2009 01:39 PM
fuel regulator smrat Engine 1 08-17-2008 05:10 AM
fuel regulator fred56 Engine 2 04-19-2007 05:01 PM
fuel regulator zephyrc Engine 1 10-25-2005 02:00 PM
