-   -   fuel regulator (http://www.hotrodders.com/forum/fuel-regulator-6444.html)
vega dog 02-13-2003 10:26 AM
fuel regulator
In need of new one which regulator is the best for my drag car with a 383ci that runs on alcohol? one more were does the regulator need too be I have been told it needs too be below carb then I seen that edelbrock makes one that bolts to plate that bolts under carb? this would be nice. thanks for the help..............
BOBCRMAN@aol.com 02-13-2003 06:46 PM
make the regulator is the last thing the fuel passes thru on its way to carb, i'm partial to the Holley, but any good quality regulator will work. set at 6 1/2-7 p.s.i.
