fuel regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2003, 09:26 AM
New Member
Post fuel regulator
In need of new one which regulator is the best for my drag car with a 383ci that runs on alcohol? one more were does the regulator need too be I have been told it needs too be below carb then I seen that edelbrock makes one that bolts to plate that bolts under carb? this would be nice. thanks for the help..............
Old 02-13-2003, 05:46 PM
BOBCRMAN@aol.com's Avatar
Post
make the regulator is the last thing the fuel passes thru on its way to carb, i'm partial to the Holley, but any good quality regulator will work. set at 6 1/2-7 p.s.i.
