Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel related questions
Old 11-15-2012, 08:58 PM
vht vht is offline
How did you open up the tank? I was thinking 1/2 in line, but I was wondering if I could install a 1/2 in line in place of the original line in the sending unit? I'm going to run a large screen type filter like the one I had on the dragster. It was easy to inspect and caught everything. Is the 80 gph pump enough or should I step up to the bigger one and run a regulator?
