Fuel related questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2012, 07:37 PM
vht vht is offline
On my 72 chevelle it has a 5/16 fuel line. I'm installing a 434, 600 to 650 hp. Don't want a fuel cell and I don't really want to put a sump in the stock tank, would a BB sending unit, 3/8, and a 3/8 line to the front be enough? I was thinking of running the Holley 80 gph pump, mech, that doesn't need a reg. I could run a 1/2 in line but I'd still have the tank issue. What's your ideas on this?
Old 11-15-2012, 08:21 PM
techinspector1's Avatar
Wiki Edits: 326
My best guess would be that at 650 hp, you'd be 100 hp over the limit for 3/8" feed line.
Here's the math for fuel required....
0.5 lbs of fuel for each hp hour, so 650 hp will use 325 lbs of fuel or 54 gallons of fuel for each hour of operation. Most pumps are rated at zero restriction, so make certain you have enough pump.
If I were in charge of your operation, I'd run 1/2" feed line and 1/2" return line with a filter on the supply (tank) side of the pump and a regulator close to the carb with another filter. Keep a close eye on the filter at the pump. If it gets clogged, the pump goes south.
Old 11-15-2012, 08:29 PM
vinniekq2's Avatar
my 434 has 1/2 inch line.took out the tank and opened up the entire system,,,,regulator is at 6 pounds.nothing less would be acceptable.I use a nascar type fuel pump
Old 11-15-2012, 08:58 PM
vht vht is offline
How did you open up the tank? I was thinking 1/2 in line, but I was wondering if I could install a 1/2 in line in place of the original line in the sending unit? I'm going to run a large screen type filter like the one I had on the dragster. It was easy to inspect and caught everything. Is the 80 gph pump enough or should I step up to the bigger one and run a regulator?
Old 11-15-2012, 09:25 PM
vinniekq2's Avatar
I pulled the tank and took it to a rad shop.I have a friend that modified the sending unit.
Dont mess around with the fuel pump,use a good one. I use a mechanical pump,most people use a big electric. intank is a good choice too
Old 11-16-2012, 06:44 AM
vht vht is offline
I was referring to a mech pump.
MPFI 3.1L gm engine hard starting, fuel related fast68 Engine 4 05-18-2009 04:16 PM
Swapping '73-'77 A-body rear end into a '71, & related questions? BinderDriver Transmission - Rearend 3 12-14-2008 01:40 PM
I'm back! With more questions. (383SBC)Transmission related too. Lord_Hate Engine 11 08-05-2007 05:30 AM
2 Gas related Questions JIm Sam Engine 10 12-01-2006 04:24 PM
Lots of Blower related questions?? HemmiGremmie Engine 5 11-13-2005 05:15 PM
