fuel return line Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2005, 07:14 PM
fuel return line Q
Hi i own a 1969 nova 350cid my question is i recently purchased this car and the kid who owned it before had on there a fuel cell. i replaced the fuel cell with the tank and ran new fuel line but other then the main feed from the tank i have three other ports two on the pass. side and one of the driver which one the those is the return linbe run into?
Old 03-12-2005, 07:34 PM
Max Keith's Avatar
fuel lines
Best thing to do is get under the car and chase the lines down and see where they go. With a stock fuel tank and carbureted engine, you dont need a return valve anyway.
Old 03-12-2005, 07:38 PM
no return needed?
there wasnt a return line on the car when i purchased it thats why i assumed i was missing one. and your sure that i can go without one with normal driving conditions and wont run into any sort of problems?
Old 03-12-2005, 08:09 PM
packratwrecker's Avatar
Too many hobbies!
69, with the correct fuel pump, should only have 2 lines anyhow. Unless you got a later pump, with the return line, I wouldn't bother with it.
Old 03-12-2005, 08:13 PM
only one line
ok now the only fuel line i have running is the main line from the tank to the fuel pump other then that there is no other fuel lines
Old 03-13-2005, 08:49 AM
Too many hobbies!
Except the one that goes up to the carb, I hope.
I wouldn't even worry about the other line. Unless the pump has an extra return line on it, it was never designed to return fuel anyhow.
Old 03-13-2005, 05:25 PM
There were 3 lines in 69. One was fuel line, one was to the charcoal canister and one was the vent. If you are not using the canister line, cap it off to keep dirt/insects out. The vent line should go to a roll-over valve installed higher than the tank top (safety item)
Trees
Simple fuel line question red_rider52 Engine 8 03-07-2005 10:08 PM
Fuel Line Q S10Fan Engine 1 07-26-2004 05:11 AM
Holley Street Avenger Fuel Line western star Engine 5 12-30-2003 09:25 AM
FUEL LINE questions tony350ss Engine 1 04-14-2003 01:01 AM
74 olds 455 little line on fuel pump 225buick Engine 2 04-09-2003 08:23 PM
