Can the return line from a BG return style diaphragm fuel pressure regulator be used to supply fuel to the fuel solenoids of a wet nitrous system?
As in, I want to supply the fuel to a 100 shot direct port fogger system on my BBC. The fuel system is a dead head, returnless system. I would use the regulator as a make shift "T" fitting. Fuel would be supplied by the return port on the regulator. Is this possible, or more importantly able to supply enough fuel without any pressure spikes?
