fuel runs back to tank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 07:43 PM
kool kat's Avatar
we have a 57 buick nailhead with the original 4 brl. carter afb.
have installed a new fuel pump and filter in the glass globe behind the thermostat housing.
after setting an hour or so the fuel emptys from the filter and the carb?
no leaks anywear...car runs fine once the gas gets to it.
where do I start...carb rebuild?
Old 05-26-2008, 07:49 PM
poncho62's Avatar
Wiki Edits: 5
Sounds like you need a fuel filter with a check valve in it, like many Quadrajets have........
Old 05-26-2008, 08:00 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
There has to be a breach in a fuel supply hose. Possibly on top of the fuel tank. Watch the filter after you turn it off for bubbles, if they float up through the filter it has a leak in the supply line. Since the supply line to the fuel pump is under suction, it may not appear to leak fuel.
Old 05-26-2008, 08:01 PM
kool kat's Avatar
could it go inline between the glass filter and the carb? thanks this old stuff is a little odd
Old 05-26-2008, 08:06 PM
kool kat's Avatar
sounds like that could be it. it also has a metal can type filter right off the gas tank...alot of rubber hoses to check and one of them could be leaking air...they are all dry on the outside...no drips.
Old 05-26-2008, 08:07 PM
My 2 cents worth
Wiki Edits: 3
Yes it could be in line after the filter, or pump, but you would see fuel leaking since this is the pressure side.
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 10:50 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Fuel Tank Remove headturner73 General Rodding Tech 6 01-15-2007 07:29 AM
Grounding a gas tank and a fuel gauge question Z-Money Pit Electrical 10 06-26-2006 09:53 PM
Fuel Tank cleaning 65Stanger Engine 2 05-07-2006 04:41 PM
