Which fuel sender? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 08:23 PM
Which fuel sender?
I have a VDO fuel gauge and I don't know what ohm it is so I can purchase the correct sending unit. Can anyone tell me how to find out what ohm the gauge would be? I have the part # off of the gauge but can't find it anywhere on the net. Sure would appreciate some direction.
Old 10-29-2012, 09:16 PM
327NUT's Avatar
Did you try calling or searching the VDO website, it lists all of the fuel sensors by their ohm's.....or the dealer you bought the gauge from.
Old 10-29-2012, 09:29 PM
Yes, I did search VDO site and could not find any info. I also completed their online form for an answer but haven't heard back. I did not purchase the gauge. It was in the car when I bought it. I think this gauge must be discontinued because I can't find the part no. on their site.
Old 10-29-2012, 09:45 PM
What is the part #?
BB
Old 10-29-2012, 10:10 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Check out the Summit Racing site. They seem to have the sender that will match your gauge.
vicrod
Old 10-29-2012, 10:47 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
This is JUST an idea ...
Could a guy ("a guy" being you) get your hands on any kind of rheostat?
I'm thinking of the type on a headlight switch or dash panel lights dimmer.
Better yet ... a fuel tank sending unit out of an old chevy!
If you attach B+ (12V) to the appropriate side of the guage, and then wire in the rheostat on the the ground side of the guage (The wire that goes to the fuel tank sender)
Begin by rotating the switch to the fully dimmed position before connecting any current. You should should show an empty tank. Slowly rotate the rheostat, and watch for the needle to move. Using a multi-meter, test and record the resistance value at this point as your MIN Ohms. Continue turning the rheostat in very small increments, pause, and watch the needle on the guage rise. When it hits the "Full" mark, test and record the resistance as your MAX Ohms.
A typical OEM GM guage should be a 0-90 Ohm. Some Ford and Chysler operated in the 10-80 Ohm, many iports were much higher.
Old 10-30-2012, 03:57 PM
Originally Posted by boothboy View Post
What is the part #?
BB
The numbers on the gauge are 301280001 and 121003477
Old 10-30-2012, 04:02 PM
I have no idea. No, I do not have a sending unit. Met a guy at a recent car show who bought a 0-90 sending unit for his car and it didn't work. He offered to sell it to me at a reasonable price but I don't want to be in the same boat. If I can't figure it out I guess I can just buy a new fuel gauge. I still haven't heard from VDO.
Old 10-30-2012, 04:03 PM
vicrod
Agree, but I don't know what ohm range the gauge is.
Old 10-30-2012, 05:28 PM
66GMC's Avatar
It does appear that VDO fuel gauge part numbers ARE in the format "301 999" or "301 999L " ... (with "9's" being Digits from 0-9, an "L" being Characters from A-Z)
I was also able to find them in the same format as you posted in a "Continental VDO" PDF catalog.
See the numerical index on PDF page 95.
Nothing that matches the number that you posted, though.
Perhaps it has been discontinued or superceded?
Try contacting VDO directly?
Old 10-30-2012, 05:33 PM
66GMC's Avatar
I'm not sure if you caught my idea or not.
The premise was to use a rheostat of almost any kind, so that you could test the guage and measure the min and max Ohm ratings using a multimeter to DETERMINE the range.
Old 10-30-2012, 07:51 PM
Yes sir I did and I will try that. Thank you for that great idea. Also want to thank you for doing that leg work. I did contact VDO vie their website but could not find a number to call. I have not heard back from them. Right now the car is in the shop getting an a/c installed amongst some other things. It should be out Friday so when I get it back I will try that.
GM Fuel Tank Sender smokey626 Electrical 2 05-05-2012 04:19 PM
89 Chevy fuel sender unstable Electrical 1 05-06-2010 07:08 PM
Fuel Sender Repair PAS55 Electrical 2 12-14-2008 09:02 PM
Fuel Sender Help 84layinframe Engine 2 05-25-2004 07:52 AM
Fuel sender/pick-up Bluepen Electrical 3 07-05-2003 09:19 PM
