Fuel Sender Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2008, 09:19 AM
PAS55's Avatar
Fuel Sender Repair
The fuel sender in my fuel cell has stopped working, I took it apart and the wire from the center terminal, that goes to the gauge, has come off the small board is it difficult to resolder it back on, how careful do you have to be with the heat on the small board. This board is where the float piece sweeps against.
Garry
Old 12-14-2008, 11:17 AM
302 Z28's Avatar
You certainly can re-solder the wire to the board, but use a small low wattage soldering iron. If you apply too much heat you will cause a separation of the foil circuit run from the board.
Vince
Old 12-14-2008, 08:02 PM
PAS55's Avatar
Thanks I got it back together it seems to work fine.
Garry
Electric Fuel Pressure Sender Location 72Orange Engine 6 02-18-2006 01:00 PM
Device for vaporizing fuel to improve economy released onto market today! club327 Engine 15 05-25-2005 07:47 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
Fuel Sender Help 84layinframe Engine 2 05-25-2004 06:52 AM
39 Chev Coupe Fuel sender Where is it? woody51 Electrical 9 05-07-2004 03:29 PM
