fuel sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2007, 03:21 PM
fuel sending unit
i wasn't sure where to put this post so i put it in the basics.
the gas gauge quit working in my 1970 oldsmobile delta 88. I don't believe it is the gauge because it has worked on and off a couple times like once i bottomed out and it worked till i filled it up again, so i thought it was the sending unit and i was wondering if anyone new what other gm models probably have the same sending unit
i went to some of the local parts stores and their books don't go back far enough any info would help
Old 07-08-2007, 04:12 PM
dinger's Avatar
I'm going to move this to the electrical section, I bet Drvette can help.
Old 07-08-2007, 04:44 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Thanks for the re~Direct, Dan!
TESTING:
Remove the sender wire from the sender.
Turn the key on, and observe the gauge..It should peg full.
Next , Ground the Sender Wire, observe the gauge..It should peg Empty.
IF you have this, the gauge and wire are whole and operating properly.If you get no movement from the gauge, Either the instruments Fuse is open, OR the sender wire is cut..hand over hand inspect the wire..If those are good the gauge is defective.
If , when (the above checks good) you reconnect to the sender, It does not work, run a jumper wire from the sender body in the fuel egress door, to a good , hard ground.Check gauge again, If that fixes it..install a proper , well bonded ground in it's place..(This is the most common problem).
IF none of those tests correct the problem, the float may be fuel logged, (small hole it it) OR the rheostat may be intermittent..Either will require dropping the tank, and replacing the float..While you are doing that..replace the fuel line pickup sock..It will save you the hassle of doing it later when it plugs up, and quits running..(and if it's stock..It's about due..)
Auto ZOne has them..you can order in person or online, here is their PN And catalog listing:
Auto Zombies
Doc
Old 07-08-2007, 08:25 PM
302 Z28's Avatar
The float fuel logged has bit me more than once. On my sons Ranger his fuel gauge was acting goofy. When it was full it would eventually go to empty after a few hours. As the fuel was used up it would start to climb. We had decided to replace the fuel sending unit one weekend. Of course he had just filled the tank up . After crawling under the truck to check out the difficulty level I determined it would be much easier to remove the bed rather than dropping the tank. Withing 30 minutes we had the bed sitting in the driveway. I had already checked with the local parts houses for availability, sorry Ford dealer item. Ford wanted $160 for the unit . After removing it I hooked it back up to manually work the sending unit. It worked properly, but I kept noticing fuel dripping from it. After a closer inspection and removing the snap on copper float I determined it was full of fuel. It had a hairline crack around a solder end joint. Called Ford to see if the float only was available....yes it was, for about $3.00. We were elated, that was one of the cheapest repairs I have ever made.
Vince
Old 07-08-2007, 09:27 PM
302 you sure hit a sore spot with me on that Ranger float, I am not making this up! In the last 4 years I have replaced two of those dang things in my Ranger, one in my son's Ranger and one in my neighbor's Ranger and I will take an oath on this-my ranger needs another one now! When I asked the man at the parts counter if this was a common problem he just laughed and said "no comment" so I assume from that and what I have seen it is very common on ford floats, at least on the small trucks. I am going to try and find a composite type float that will fit this time.
Old 07-09-2007, 05:55 AM
302 Z28's Avatar
Must be something to it .
Vince
Old 07-09-2007, 06:34 PM
thanks for the info all i am going to get atr that soon
it sticks on full and has worked i believe twice since it stopped working so... I tried cleaning the ground once but it didn't fix it of coarse
aod speedo sending unit ? 56f100 Transmission - Rearend 2 09-30-2005 06:23 AM
oil pressure sending unit fireguy Engine 5 02-11-2005 09:09 AM
Gas Gauge stopped working has power to it maybe sending unit??? 61ChevyTruck Hotrodding Basics 8 11-04-2004 09:02 AM
73 Pontiac Firebird Fuel Pickup Sending Unit Rad Ray Engine 3 02-05-2003 08:39 AM
Oil Sending Unit Assistance MI2600 Engine 3 09-11-2002 07:55 AM
