Fuel System - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 12:58 PM
Fuel System
Looking for suggestions for a fuel system problem - I have a 39 Ford with the original fuel tank that has been dipped, cleaned and painted. Fuel filter and fuel line has been run up over the axel and down frame rail to the high volume mechanical fuel pump.
Problem - If I let the car sit for more than a couple of weeks without starting, I lose fuel to my fuel pump. I do not have leaks or puddles on the floor and I cannot figure out why or where the fuel is going, barring it getting sucked back into the tank.
Any suggestions would be appreciated.
David
Old 03-31-2007, 06:38 PM
Remount the pump as close to the tank as possible, electric fuel pumps push hard but don't pull very much, I would mount it lower than the bottom of the tank between the rear axle and the tank
Old 04-01-2007, 10:56 PM
Fuel System Problem (2)
Thanks for the response beach10222. I have a high flow mechanical fuel pump, not electric. I can't move it from it's engine mount position. Are you suggesting replacing the current fuel pump with an electic pump?
Do you have any suggestions that might explain the problem while using a mechanical fuel pump?
Old 04-02-2007, 07:10 PM
Sorry, I didn't pick up on the mechanical part, yes an electric pump would solve the problem but they tend to be noisy. As for your mechanical pump problem it is most likely the incoming check valve inside the pump it seems once they pick up some trash they won't free up and close again, that allows fuel to drain back into the tank. If your pump is held together with screws you can take it apart and clean the valve, if not you can try air pressure but no more than 15 lbs. or so.
Good Luck, Dave Johnson
Old 04-02-2007, 07:51 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Another thing to check is whether your vent to the tank is plugged. If it is when you are running you create a partial vacumn in the tank and when you stop it will very slowly suck the fuel back into the tank.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
returnless efi fuel system william27103 Engine 17 10-28-2005 12:21 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
Fuel system q, dry at the carb, but fuel bows full? killerformula Engine 6 09-18-2004 06:07 PM
Fuel Management system rdaniels Hotrodders' Lounge 1 01-07-2003 08:33 AM
