fuel system - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2010, 11:41 PM
fuel system
fuel pump will not pump 1998 honda accord lx changed pump 3x
Old 03-04-2010, 10:20 AM
Last journal entry: 50 Ply wagon
check your electrical connection........could be a bad ground.
Old 03-04-2010, 07:48 PM
T-bucket23's Avatar
Wiki Edits: 26
Have you checked the relay operation. The distributor module will also keep the pump from running. A bad tank ground could also be an issue. You need to get out a meter and see where it is failing.
Chet
fuel system parameters- I wanna finish this tonight! Jeff The Ruler Hotrodding Basics 3 11-11-2009 02:39 AM
street rod fuel system czmpjx General Rodding Tech 2 11-26-2007 12:58 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
Fuel system q, dry at the carb, but fuel bows full? killerformula Engine 6 09-18-2004 06:07 PM
