fuel system flush - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 02:37 PM
fuel system flush
I got a 91 geo strom from a buddy for nothing.. Its been sitting in his garage for five years with a half tank of gas in it..It started right up ( with a jump) and run perfect for the time it went from the garage to the car tote..Then started missing and wouldnt keep running..I think the bad gas made its way to the motor and caused the problem.. ok now. 1991 geo storm GSI efi what would be the best way to flush out the old fuel in the system to make way for new gas...Thnx
Old 06-02-2008, 03:58 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Best bet is to drop the tank empty it and clean it out, and remove the fuel filter, and take the fuel line off of the injector and blow the lines out. Get a can of fuel injector cleaner and add it to the new fuel. This should clean it the rest of the way.
Old 06-02-2008, 04:10 PM
Wiki Edits: 31
I would use Sea foam instead of injector cleaner, it's a little stronger but still safe to use and it has a upper cylinder lubricant and serves as an octane booster.
Old 06-03-2008, 11:37 PM
Once you get the fuel system cleaned up, change the spark plugs, which have likely been fouled by the bad gas.
Old 06-03-2008, 11:58 PM
My 2 cents worth
Wiki Edits: 3
Also be prepared to replace the O'2 sensor, which could be fouled.
hydrogen booster / more mpg hottrodz Engine 39 08-28-2008 02:09 PM
street rod fuel system czmpjx General Rodding Tech 2 11-26-2007 12:58 PM
Fuel system question 475_enduro Engine 1 02-08-2007 10:23 PM
60-degree v6 fuel system issues. ChevelleSS_LS6 Engine 0 05-22-2006 09:38 AM
Fuel System 41willys General Rodding Tech 2 10-08-2005 08:17 AM
