-   -   Fuel System for Fox Mustang w/ carbed stroker 331 cid (http://www.hotrodders.com/forum/fuel-system-fox-mustang-w-carbed-stroker-331-cid-141921.html)
Tu Lowd 07-13-2008 06:49 PM
Greetings All:
Building a fuel system in preparation for my 500+ hp naturally aspirated, carb'ed small block. Currently have a tank sump and a big Russell Spin on fuel filter with two 1/2" NPT fittings each.
Looking at using a Holley Black pump for primary fuel supply with single -8AN braided hose and filter and regulator under hood. I may add a separate small nitrous system (100-200hp)with separate pump and line later.
Is #8 line big enough, and is the 140gph enough to support my Holley 750 DP.
Any comments or suggestions appreciated!
Paul
poncho62 07-13-2008 06:51 PM
welcome Paul....I am moving this to the engine forum.......you will get answers there.
Tu Lowd 07-14-2008 05:34 AM
thanks for ur help
appreciated, thx!
ScoTFrenzel 07-14-2008 11:49 AM
Basicly on a pusher pump system you want a rated capacity (at your pressure) to be twice the volume needed by the engine so as to overcome inertia, etc.
I'm sure several others will have more specific input.
