Fuel System for Fox Mustang w/ carbed stroker 331 cid - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 05:49 PM
Greetings All:
Building a fuel system in preparation for my 500+ hp naturally aspirated, carb'ed small block. Currently have a tank sump and a big Russell Spin on fuel filter with two 1/2" NPT fittings each.
Looking at using a Holley Black pump for primary fuel supply with single -8AN braided hose and filter and regulator under hood. I may add a separate small nitrous system (100-200hp)with separate pump and line later.
Is #8 line big enough, and is the 140gph enough to support my Holley 750 DP.
Any comments or suggestions appreciated!
Paul
Old 07-13-2008, 05:51 PM
poncho62's Avatar
Wiki Edits: 5
welcome Paul....I am moving this to the engine forum.......you will get answers there.
Ontario Rodders
Old 07-14-2008, 04:34 AM
thanks for ur help
appreciated, thx!
Old 07-14-2008, 10:49 AM
Basicly on a pusher pump system you want a rated capacity (at your pressure) to be twice the volume needed by the engine so as to overcome inertia, etc.
I'm sure several others will have more specific input.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
65 mustang fuel system novil01 Hotrodders Site Suggestions and Help 1 07-20-2007 08:13 PM
fuel system ???? fitzwell Engine 2 08-02-2006 03:25 PM
Fuel system woes frankenstang57 Engine 6 04-10-2006 06:57 PM
Mustang guys Help! tm454 Engine 19 10-23-2003 05:37 PM
