Fuel System-Open - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2014, 10:33 AM
Roadster28's Avatar
Fuel System-Open
Hmmm...the Roadster I bought was built by an "expert." I am trying to figure out why the fuel tank was vented by running the vent hose into the trunk and then back to the vent tube. I suspect that whatever the goal, it did not work and the vent hose was cut. Does anyone know why I should not run the vent hose directly to the vent tube? I have tried to capture the problem with the pictures. Oh, It is painfully slow to fill the gas tank. Maybe the builder thought venting was the problem. Notice the kink. That would explain the cut. However, the problem with filling the tank has more to do with a horizontal fill tube with two right angles. At least that would be my guess.
I am in favor of running a short vent hose to the vent tube. What do you think?
ID:	129434   Click image for larger version
ID:	129442   Click image for larger version
Old 03-20-2014, 06:11 PM
techinspector1's Avatar
Wiki Edits: 326
I'm confused. It looks like the vent line has been cut to make it operate as a vent, but it is venting into the trunk area of the car and creating a potential bomb. Is that right?
Vent the tank to the outside of the car.
Old 03-20-2014, 06:34 PM
Roadster28's Avatar
Nope...not very smart venting into the trunk, but I have corrected the problem. I just can't believe it was done the way it was done.
fuel psi when open cutouts? blackrider71 Engine 4 06-24-2010 10:51 PM
Throttle my 470hp engine with shorty's headers , simmons 2.5" open mufflers & system? Berres Engine 2 03-28-2010 02:22 PM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 08:34 PM
Fuel system q, dry at the carb, but fuel bows full? killerformula Engine 6 09-18-2004 07:07 PM
no fuel inside carb when i crack the throttle open Moteman Engine 2 09-18-2002 05:57 AM
