Fuel system woes
Here's what I've got; '88 Mustang LX that has a 429 in it. The car is race only and is used at the strip and auto-x. I originally built it 4 years ago and have ran it for 4 seasons. Last year I started having fuel starvation problems which lead to the point on no fuel pressure. I removed the mechanical fuel pump(big Holley, not OEM) thinking it was the culprit. The fuel pump appears to work just fine off the car. I figured since the pump has a monster spring, and since I re-used original eccentric ring on the front of the cam(questionable mileage/ came with the motor) it was probably toast. I figured I'd just run a block off plate and an electric pump. The car has 3/8" line running from the tank to the front. I also gutted the original FI pickup and it is 3/8" as well. I installed the new pump under the backseat floor on the driver's side. It sits below the tank. Well after everything is said and done, still no fuel pressure. I think it may have something to do with the pickup now, but how does the pump in relation to the tank affect things? I probably could move the pump back some more above the axle, but the floor was one of the easier locations. Any suggestions? Thanx! BTW, like I said, the old setup worked fine for 3 seasons...
That's what I'm guessin' now too. Does the location of the pump sound OK?
How far ahead of the tank is it. Below tank level is good, but if I remember right, they are supposed to be approx one foot from the tank for optimal results. If it's around there, you sound good.
It's about 18" ahead of the tank. Just in front of the axle. If I put it above the axle then it will be mounted to the floor at the same level as the top of the tank.
Fuel system woes
Most electric pumps are designed to push and don't pull to well. But with the short distances you are talking about that should not be a problem. Did you check the fuel filter?
Where are you measuring your fuel pressure ? Do you have pressure right after the pump? Last edited by home brew; 04-10-2006 at 12:56 PM. Reason: additional questions |
And the problem was...
$0.50 worth of hose... Oh well, live and learn. Question is, does race gas eat rubber hose? I noticed everything I replaces was getting hard and crunchy. More so than you'd think in just a few years. |
| Charging system info............... | poncho62 | Electrical | 11 | 11-26-2005 08:53 PM |
| 93 Suburban fuel pump | sabino56 | Engine | 8 | 09-10-2005 02:54 PM |
| Carb size to small???? | brainsboy | Engine | 50 | 08-14-2005 04:04 PM |
| 93 camaro fuel system | k-star | Engine | 7 | 01-26-2005 01:30 PM |
| Fuel Management system | rdaniels | Hotrodders' Lounge | 1 | 01-07-2003 08:33 AM |
