fuel tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2007, 11:37 PM
fuel tank
i have a 92 explorer that leaking gas. it looks like it's coming from the top of the gas tank, also sometimes when i turn it off i can hear like lost pressure there. is there anyone that had this problem or can tell me whats wrong
Old 07-27-2007, 06:44 AM
cboy's Avatar
Last journal entry: Finished
I'm guessing that is a one piece, internal pump, pickup, vent unit. Two things come to mind immediately. One, the gasket which seals the unit on top of the tank has been compromised or two, the vent tube or supply tube has a hole/crack in it.
Does it only leak when you have a full or nearly full tank or does it leak all the time?
Unfortunately, I think you are in for a bit of work to determine for certain what the problem is. The tank will most likely need to be removed to get at the top and the pick-up/venting unit.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Use in tank fuel pump or no? BillyJoe General Rodding Tech 7 05-15-2007 08:39 AM
Grounding a gas tank and a fuel gauge question Z-Money Pit Electrical 10 06-26-2006 09:53 PM
fuel tank help markadele Hotrodders' Lounge 3 12-05-2005 10:00 PM
fuel tank opinions guba_unus General Rodding Tech 4 01-05-2005 10:09 PM
fuel tank question HARVICKx29 General Rodding Tech 2 09-07-2004 03:22 PM
