Fuel Tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2007, 03:24 PM
Last journal entry: 1950 chevy 3100 P/U
Fuel Tank
I have a question about my fuel tank in my 1950 chevy truck. I am turning it into a hot rod and i was wondering if it would be ok to just leave the tank behind the seat or if i should do a rear mount tank under the truck bed.
Old 09-26-2007, 04:16 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You can do either one...but personally , I prefer mine under the truck. That way its somewhat safer...for instance if a hose cracked or came loose with it in the cab .
Old 09-26-2007, 08:00 PM
Last journal entry: 29 Ford Tudor
I debated that on my 53 for a while but in the end I decided that the original hoses lasted 50 years so the new ones behind the seat should last me as long as I will have it which is probably forever.
Charles
Old 09-27-2007, 09:09 PM
I am going to keep the behind the seat tank and add a Blazer tank between the rails in the rear. Do a search for "blazer millitary surplus fuel tank" and you can buy a new one for 25.00, get your sending unit and straps from LMC, then move your rear crossmember back and set it in.
Good luck.
http://community.webshots.com/album/556111970egYVwn
Fuel Tank and Radiator Springs? 35WINDOW General Rodding Tech 3 07-26-2007 07:58 AM
Use in tank fuel pump or no? BillyJoe General Rodding Tech 7 05-15-2007 09:39 AM
Grounding a gas tank and a fuel gauge question Z-Money Pit Electrical 10 06-26-2006 10:53 PM
fuel tank opinions guba_unus General Rodding Tech 4 01-05-2005 11:09 PM
fuel tank question HARVICKx29 General Rodding Tech 2 09-07-2004 04:22 PM
