Fuel Tank cleaning - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2006, 03:41 AM
65Stanger's Avatar
Check the water, check the oil
Fuel Tank cleaning
How would I go about cleaning the fuel tank on a 1965 Mustang? I'm replacing the fuel pump and fuel lines next, and I am thinking about cleaning out the tank as well, as I don't know when it was cleaned last (if ever). do I just drop the tank drain the gas out into a big gas can and put some kind of solution on it? Is there anything special I should use? Thanks. Also, when I puel my fuel pump, is any oil gonna come rushing out, or will all the oil be in the pan by that time and should I not expect any to leak out?
Old 05-07-2006, 06:28 AM
you don't clean a gas tank, you replace it when it leaks
you have a filter on the pump to clean the gas coming from the tank, replace the filter per the manual mileage instructions, your tank is old and corroded = more scale, change it twice as often as recommended
you don't change a fuel pump until it tests bad for pressure
you don't replace gas lines till they leak
YOU DO REPLACE THE STEEL BRAKE LINES AND BRAKE HOSES if they are old and corroded even if they are not leaking!
Name:	mustang maintenance chart.jpg
ID:	12032   Click image for larger version
Name:	service schedule.jpg
Old 05-07-2006, 05:41 PM
techinspector1's Avatar
Wiki Edits: 326
If you feel you have to clean it, take it down and pour out the contents. Pour in about a quart of kerosene and drop in a length of chain. Get a couple of buddies over to help you slosh it around and back and forth. This should dislodge rust and crud. Repeat as many times as are necessary to get clean kerosene when you empty it. Re-install and change all fuel filters.
Fuel Tank for 50 Chevy P/U DirtDoctor Hotrodding Basics 8 01-14-2006 07:43 AM
fuel tank help markadele Hotrodders' Lounge 3 12-05-2005 11:00 PM
beer keg fuel tank jwhasemeier General Rodding Tech 16 08-25-2005 10:45 AM
fuel tank ground friend Electrical 2 09-02-2004 07:20 PM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 05:55 PM
