Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Tank Installation Plumbing Questions
Old 01-04-2004, 10:02 AM
Shortstep Shortstep is offline
Gettin a life..Goodbye
I don't think the two tanks have to be same level as long as the tops are the same level and the T is below both tanks. One tank will run out first but this shouldn't be a problem. Or you could just do like on a motorcycle and have a spare tank. Put a valve for the tank with a gauge and cut it off until you run out or nearly out and then go to the reserve tank. Of course this is a little risky in traffic so you might want to plumb it for easy access.
