Fuel Tank Position - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 06:44 PM
Last journal entry: More painting pics
Fuel Tank Position
Does anyone know of a rule in any state that affects the position of the fuel tank on a hot rod?
Old 03-29-2009, 07:58 PM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know of any laws pertaining to position. fmvss website does have laws pertaining to crashworthiness, and post crash fuel system integrity...
Check this PDF out, it makes for some interesting reading...NOT! (scroll down a page..it's under the directions for "school bus seat")
But it does tell you how to build the cart and barrier that you'll need to do your own mounted fuel tank crash testing.
http://frwebgate.access.gpo.gov/cgi-...=2001&TYPE=PDF
I'd mount it where ever it will fit, not drag on the ground and with the filler on the top.... .
Later, mikey
BE different....ACT normal.
Old 03-30-2009, 12:38 AM
techinspector1's Avatar
Wiki Edits: 326
Some states have laws prohibiting bottom supply lines, so run your line out the top of the cell if you can, or build sheetmetal around it so a cop or inspector can't see the supply line coming out of the bottom.
Old 03-30-2009, 08:55 AM
Later, mikey
Wow Mike I am impressed you read that whole thing, my eyes glazed over after the first paragragh. So I assume it is ok to go ahead and put it in roughly the same position as the 32 Ford -- hanging out aft of the rear axle?
techinspector -- Because of the likelyhood of leaking fittings?
Old 03-30-2009, 09:11 AM
Frisco's Avatar
Glad To Be Here
I would assume that any state or Federal laws (rule) pertaining to the placement of a fuel tank would only apply to newly constructed vehicles that would then be registered as "new".
I don't think that any laws would be retroactive for existing vehicles.
Some examples of existing vehicles and gas tank placement:
Ford Model 'T' had a gas tank under the front seat. The seat cushion was raised to fill the tank.
Ford Model 'A' had the gas tank as part of the dash with the shut-off valve & carburetor supply line directly in front of the passenger.
The 1932 Ford had the gas tank fully exposed just below and behind the rear of the body.
Early 50's Chevrolet pickups (and others) had the gas tank directly behind the seat inside the passenger compartment.
The list goes on.
All of the above examples are legal for the vehicles mentioned. None would be approved if they were manufactured that way today as "new".
Old 03-30-2009, 07:19 PM
Wiki Edits: 326
"techinspector -- Because of the likelyhood of leaking fittings?"
No, because of the possibility of road trash yanking the fitting out of the tank/cell and spraying fuel onto the roadway.
Building Fuel Tank.... 71gtx General Rodding Tech 12 10-06-2008 03:56 PM
Use in tank fuel pump or no? BillyJoe General Rodding Tech 7 05-15-2007 08:39 AM
Grounding a gas tank and a fuel gauge question Z-Money Pit Electrical 10 06-26-2006 09:53 PM
fuel tank ground friend Electrical 2 09-02-2004 06:20 PM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 04:55 PM
