Fuel tank sender - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2011, 09:44 PM
Fuel tank sender
Yes I have a 02 trans am -Camaro 5.7 fuel tank in my 53 chevy pickup, And i have installed Dolphin gauges in the truck my question is how do I adapt the newer fuel tank with the 4 wire plug in to apapt to my fuel gauge on my Dolphin gauges
Thank you
Old 07-16-2011, 08:35 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
install the sender from the gauge kit, or snap a picture of what you are trying to describe and post it. I think that the tank has a fuel pump there and some of the plug is wired for that . No matter those Dolphin gauges are sender specific to give accurate readings, and will need there sender in there.
The other option you have is to ohm out the senders. GM is 90 ohms, that will be in the tank. Read the Dolphin sender if it is the same then the tank one will work just fine.
Old 07-18-2011, 01:50 PM
RippinRon's Avatar
This is the plastic tank? The fuel level sender on these is not standard 90ohm gm. Its 240 full 33 empty. Autometer has a universal sending unit or a programmable gauge.
Old 07-18-2011, 08:15 PM
pepi's Avatar
Plastic tanks if I am reading you correct can be ordered either way ford or gm senders installed.
He already has Dolphin gauges so why would he want to change that for autometer?
Old 07-19-2011, 03:29 PM
RippinRon's Avatar
I'm saying the stock tank for 1999-2002 f-bodies is plastic and has an oddball full and empty resistance for the fuel sender. His gauges are likely are not setup for them. Farmall did you happen to swap the trans am's ls1 into your truck? Is that why you are using this tank?
Old 07-19-2011, 09:53 PM
fuel sender
No i'm using the LS motor out of a 2005 Chevy pickup
Old 07-19-2011, 10:15 PM
RippinRon's Avatar
Regardless your going to have to talk to dolphin and find out what ohm your fuel gauge works in and see I they can match your fuel sender.
Fuel Tank Sender.. requires earth? duncan_m Electrical 2 08-02-2008 12:02 AM
Fuel tank sender 53 chevy propaneburner Electrical 4 03-10-2008 04:09 PM
gas tank pickup/sender MOD. frank88chevy Hotrodding Basics 1 01-12-2008 07:57 AM
Fuel Sender Help 84layinframe Engine 2 05-25-2004 06:52 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
