Fuel Tank Sender.. requires earth? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2008, 09:16 PM
duncan_m's Avatar
Hi,
I've fitted a new tank to a Bedford truck, its bolted to the right hand main chassis rail.. I've used rubber strips between the tank and the steel straps that strap it to the rail.. effectively the tank is therefore insulated from the rest of the truck...
The fuel sender would require the tank to be earthed wouldn't it? There's only one connection on the top of the sender.
Cheers, Dunc
Old 08-01-2008, 10:45 PM
powerrodsmike's Avatar
Wiki Edits: 161
Run a seperate wire from one of the mounting screws on the sender back to the ground, (earth), on the fuel gauge. This is the only way to be assured of an accurate reading.
You can just run a ground strap from the sender mounting screw to the body, (or where ever your gauges ground), but those connections usually corrode over time and give a false reading at the gauge.
A gas sending unit is basically a variable resistor, and the gauge reads the resistance. When the connections corrode, it adds to that resistance, causing gauge error or a total failure to read the sender .
Hope this helps.
Mikey
BE different....ACT normal.
Old 08-02-2008, 12:02 AM
duncan_m's Avatar
Originally Posted by powerrodsmike
Hope this helps.
Mikey
Thanks Mate! That was perfect.. all wired up.
Dunc.
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
fuel anti spill valve for gas tank jbinwa General Rodding Tech 2 09-16-2007 08:57 AM
Replacing in tank electric fuel pump scot Hotrodding Basics 6 01-21-2006 01:40 PM
installing a fuel tank sump flaming79 Engine 3 01-14-2006 06:13 AM
fuel tank question HARVICKx29 General Rodding Tech 2 09-07-2004 03:22 PM
