fuel tank switch on Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2004, 04:00 PM
69elcaminoss's Avatar
1984 Chevy short box Silverado.
I can only get the truck to pull fuel from one tank. I bought a new switch and installed it but it still won't switch off of the driver's side tank over to the passenger's side tank.
Any ideas? By the way, I checked the fuse panel and I didn't see anything at all related to the fuel tank.
Old 04-12-2004, 05:47 PM
Pony's Avatar
Have you checked the switching solenoid under the truck by the tanks? Sounds like that could be your problem.
Old 04-12-2004, 10:05 PM
Thanks, I'll do that tomorrow!!!!
Old 04-14-2004, 02:08 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
You might look at the condition of the hose too. I had a leak in mine, didn't lose gas but sucked air. So not much gas got to the fuel pump. Good Luck! ...Mark
Old 04-18-2004, 12:27 AM
are you sure you have power at the switch or solinoid?
