fuel tanks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2002, 10:22 PM
New Member
Post fuel tanks?
Do any of you know if those fuel tank restoration kits actually work, or if it is better to have someone else restore my fuel tank?
-Levi
Old 08-31-2002, 10:46 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Go get tanked!
HK
Old 08-31-2002, 11:36 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I've restored several tanks. The kits work but sometimes yoou need to do a little assist. If the rust buildup in the tank is a lot, dump some roofing tacks in it and vigorously shake them with some stong cleaner to dislodge the loose stuff. Once you get clean water from this procedure, go with the rest of the kit's directions. The real key to these kits is the rubber lining.
Old 08-31-2002, 11:53 PM
New Member
Post
the tack ideal is a good one we used a chain to break loose all the crude in the tank but it was a real pain to fish out
Old 09-01-2002, 08:38 AM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Post
A handfull of good sized gravel will work better than the tacks, heavier, and probably cheaper too!
Just my 1 cent's worth. (Too cheap to use 2 cents) :p
M.F.
Old 09-01-2002, 08:40 AM
Post
I used a two part epoxy to coat the inside of my homebuilt tank for my 23 T-Bucket, to keep in from rusting. Will look up the suppliet if you want it.
M.F.
Old 09-02-2002, 09:33 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Post
Spook, I had the tank for my 48 Chevy cleaned out at a radiator shop at a cost of $110. For me it was well worth the cost because I didn't have to do the nasty heavy work. it came out just like a brand new tank.
lol AL
Old 09-03-2002, 12:52 PM
Madd Syntst's Avatar
Returning American Maddman
Post
I've used Eastwood tank stuff on a 53 Chebbie with no worries. I can't help it, I like thier products and never had a problem with them.
I used a chain that time as well.
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 11:50 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 10:12 AM
Fuel Filter Location leejoy Engine 7 05-04-2006 09:50 AM
Dual gas tanks with EFI dh79 General Rodding Tech 9 01-13-2006 08:40 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 05:04 PM
