Fuel in turbo 350 vacuum modulator line - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2013, 02:56 PM
Hello guys sorry to bother again but I changed out my vacuum lines the other day since they were old and when I took off my line going to my vacuum modulator on my turbo 350 a big gush of fuel squirted out all over my hand and this line is about four years old so it was never unhooked since it was installed. My questions are what would cause this and my transmission still shifts ok so I think my modulator is ok for now but what and how do I fix this problem?
It seems weird that a line that has vacuum suction can have fuel at the bottom of it. The vacuum modulator line is curved up from the back in a loop then goes straight up the back of the transmission straight up by the dipstick tube and straight across the intake and then is hooked up into a t fitting that has my distributor vacuum advance hooked up to it then hooked up to the front of my holley carburetor base plate.I did a google search and can't come up with anything. Thanks for any help.
Old 10-14-2013, 03:09 PM
techinspector1's Avatar
Wiki Edits: 326
There is a threaded bung hole on the top of the intake manifold. Run your modulator line from that port. If you're using that port already for the power brakes or other vacuum-operated accessory, screw a vacuum tree into the port and run as many lines off it as you need to.
Old 10-14-2013, 03:17 PM
Hey Techinspector1 thanks I was thinking about running it from that port I will do so and see how it does. Thanks again.
Strange vacuum line hookup to modulator on T-400 MJS69 Transmission - Rearend 5 05-21-2013 08:50 AM
Fuel in vacuum modulator line Yegster Transmission - Rearend 9 06-23-2011 07:20 PM
Th-350 vacuum modulator monzter Transmission - Rearend 12 09-01-2010 10:48 AM
Is there a vacuum line on a turbo 350?? APalusky Transmission - Rearend 4 04-02-2010 07:15 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
