IMO, same of fuel flow, same usage. You just wouldn't get as far in the vehicle with more load, like climbing a hill vs. flat road. You might not even get over the hill...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
First of all, you can't have two otherwise identical engines at different RPMs at the same throttle opening with the same load at steady state conditions. If one is accelerating or decelerating and the throttles just happen to be at the same position, all bets are off since you'll be using transient fuel circuits like the accelerator pump. If the engines are truly identical and have the same load, they will be at the same throttle opening at the same RPM.
In any case, if we're talking about steady state fuel flow from the mains only, and ignoring any variables like vacuum secondaries, then the engine with more airflow will draw more fuel. |
It sounds to me like if they are both steady state, then the manifold vacuum must be the same for both states (since the throttle is the same). So I think they would both pull the same amount of fuel...the 2100 rpm will just have a richer AF than the 3100.
Oh well, I could also be completely full of it.
You want to find out, are you man enough?
Go to http://ecomodder.com/ and you will see guys talking about fuel usage who know more about the subject than you ever thought possible.And believe what is discussed over there, I thought I had an idea about fuel economy, less drag, less rolling resistance, bla bla bla. They blew me away and I can by simple driving techniques change my fuel usage by 30% EASY, they REALLY know their stuff. Post your question there. Brian |
Then like you say, I could also be completely full of it. |
Hmmm...I guess you're right, cobalt.
This is a great discussion...I really want to understand this stuff a lot better. Perhaps we should just switch to electric cars.
The vacuum gives a direct idea of fuel consumption. If your build can get 14" vacuum cruising , it will achieve 14 mpg. 15 for 15, 16 for 16, etc.
| Can a throttle body injector spray TOO MUCH fuel? | scrot | Engine | 5 | 08-18-2009 10:51 AM |
| Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) | Viet Nam Vette | Engine | 4 | 06-13-2005 04:29 PM |
| Abnormal Fuel usage | Cruiseomatic | Engine | 14 | 08-31-2004 10:29 PM |
| flywheel usage | Ned-the-wrench | Transmission - Rearend | 2 | 12-03-2003 01:09 AM |
| no fuel inside carb when i crack the throttle open | Moteman | Engine | 2 | 09-18-2002 04:57 AM |
