Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel in vacuum modulator line
Old 06-19-2011, 07:11 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
in the old daze when transmissions had vacuum lines on new cars... you often would notice a u shaped loop that went 'up' near the hook up to the vacuum source at the manifold.
That loop 'up' , then down towards the trans , prevented fuel from traveling down the vacuum line tube. Any fuel would drain out of the vacuum tube because of that loop
