fuel wash edelbrock rpm heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2005, 02:14 PM
roy383ci's Avatar
hi
i got a used set off edelbrock heads for my chevy 383
the chambers of the heads weren't cleaned
if i see in the combustion chamber there is a clear spot
on the heads wall near the plug and under the intake valve
the heads are 70 cc
as far as i know from the head porting books this is fuel wash
and will be bad for performance.
i cleaned up the other head by light grinding ,unshrouding the valves
and made the ports even width
maybe the unshrouding would help
what can i do to prevent this or is this normal
thanks
Old 11-17-2005, 10:11 PM
New Member
Get your heads on a flow bench and see whats going on.
Index your plugs.
Be sure your timeing is properly indexed.
Check fuel flow in your intake.
Let me know what happens.
P.S. Do not over polish those heads until they are flow tested. LOU
Old 11-18-2005, 07:49 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Probably just a tuning issue or a type of fuel additive he was using.
Old 11-18-2005, 09:57 AM
roy383ci's Avatar
thanks for response
i dont got or know somebody with a flow bench over here.
i am not going to polish the intake only the chamber and ex port
i bought the heads used so i didnt know what the other owner off the heads
did with it or how it was tuned
thanks
Old 11-18-2005, 10:13 AM
It's best to read the combustion process off the top of the piston, not the head. That area of the head would be a high velocity area and I don't think your seeing anything abnormal.
A flow bench is not going to tell you anything except what the heads flow. You'd need to wetflow the head and very few of those types of machines are out in the field.
RPM at WOT decreases..Starved for fuel?? tommytempest Engine 10 11-19-2005 08:54 AM
suggested max. RPM for Vortec heads? Berliner Bel Air Engine 2 11-14-2004 10:20 PM
please help setting up edelbrock heads tirefryin_s10 Engine 12 07-08-2004 01:24 AM
Question for Edelbrock Performer fuel pump owners HotRodF100 Engine 1 07-20-2002 04:47 PM
Holley fuel injection with Vortec heads onna SBC. Pappy Engine 3 06-06-2002 11:17 AM
