fueling the beast - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2012, 03:30 PM
Last journal entry: getting closer
fueling the beast
Hi, I have a 1929 mercedes kit car,it has a sbf 438 stroker approx 650 hp with 13 to 1 comp, what can I do to mix a fuel for everyday street use that wont eat the pistons, and give pre ignition?
Old 01-09-2012, 03:47 PM
327NUT's Avatar
Nothing, you have a race car engine in a street driven car. You either run race gas or tear the engine down and get your compression down to a reasonable 9.5/10.0:1. This will also mean that you will have to install a new cam that will be compatible with the lower compression.....among other things.
Old 01-09-2012, 04:06 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
What Are you basing your comp. ratio on? Give us some info Head cc, - or + piston volume , head gasket bore and thickness, deck clearance, bore and stroke.
If your actually at 13 to 1 your going to have to mix racing fuel with racing fuel !! Im running Jahns forged 12 to 1 pistons to get 10.5 to 1 actual compression and my street fuel is 110 octane without my timeing cranked way back and my cam advanced!!
Jester
Old 01-09-2012, 04:10 PM
I agree 500 percent with 327 nut you either miss calculated or have to rebuild to run a mix with pump gas!!!
Old 01-09-2012, 06:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I can't imagine that type of kit car having that kind of engine in it. It looks like more of a cruiser than something that would have 650(!!!) naturally aspirated HP. Would take a loosey-goosey torque converter if it's an AT and short rear gears either way. Traction? Good luck w/that! Just seems like a mismatch to me, YMMV.
In any event, that much CR will take a minimum of 100 octane race fuel like Rockett, having aluminum heads will give you a little leeway but the tune needs to be spot on w/a good cooling system to boot. TOTAL TIMING IS CRITICAL as I'm sure you know.
Another option is to run E85. What fuel have you been using, or is this a fresh engine?
Old 01-09-2012, 08:16 PM
fresh
The engine is new I bought it for my race car but put it in the kit for a bit of fun. I was hoping to use avgas to offset the price of race fuel for a couple of runs to see how she likes the power and torque,I plan to build a much calmer engine for the car to use on the street. But it has to enjoy the beast for a while until I get the tbird finished.I know its not going to hook up very easy so i have done some chassis work to help that out. I also will try to get it to get it to stick on the track with a set of 10.5s by 28dia i'll just have to start softly. "like thats going to happen"
Old 01-09-2012, 08:31 PM
the beast
its a 438 dart shp block,srp 12.5-1 flat top pistons,4.125 bore4.1 stroke,6.2eagle hbeam rods,comp mechanical street roller cam rpm range 3200-7200,60cc pro comp heads 205 intake runners, no dyno run so just estimating.
Supercharger fueling Turbo1002 Engine 2 06-28-2009 08:50 AM
Constant flow Fueling Littledan Engine 2 11-15-2004 02:44 PM
Multiple Pressure Fueling baldric Engine 2 08-30-2004 11:38 AM
Fueling my 400 sbc Sampson Engine 5 07-07-2003 09:53 AM
the beast redneck694x41 Transmission - Rearend 2 11-23-2002 02:46 PM
