fuely heads on a 327? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 07:38 AM
Burnin that Gasoline..
I have a pair of gray fuely head that have been port and polished with new powder coating and they look pretty nice. im wondering if they will bolt up to my 327. I got the heads from a friend and i dont know too much about them. Anybody got anymore knowledge about thease bad boys. Thanks for any info.
Old 04-10-2013, 08:00 AM
vinniekq2's Avatar
they are antiquated for making power. other than that if the castings are still good,remember the are 45 years old,use them for a mild engine or buy something new and make more power and probably burn a little less fuel
The Following User Says Thank You to vinniekq2 For This Useful Post:
64 chevy step (04-10-2013)
Old 04-10-2013, 08:10 AM
fuely heads
Ok. so they probly wouldnt do to well with a RV cam i have in the 327 now? also i have the orig 4 on the floor trans wich really only gives me three gears..
Old 04-10-2013, 11:24 AM
Pocket-ported and port matched with a good 3-angle valve job, they are great heads that can easily make over 375 hp.
Header Power Bracket makes a really nice alternator mount for your headers for these heads.
Old 04-10-2013, 11:55 AM
trans
Its kinda cool having the orig trans just for its originallity but with the cam gear in it slowin me down for sure. i dont haul too much and it aint no rock crawler.the first owner had it on his farm for a long time so im sure he benifited from the low gears. it tops out at about 65 (70 is pushing it) with the rpms at about 3500-4000 im probly gonna change out the cam to get a lil more out of it... any suggestions for the 327 and a 4 gear trans???
Old 04-10-2013, 12:21 PM
Faith - Respect - Trust
I think that they would be cool just for the nostalgia of having...as in the Bruce Springsteen song "Racing in the streets", "fuelie heads with a hurst on the floor"...to bad he was talking about a 396, that never came with fuelie heads. Bit of an error on Bruce's part but still a cool song, just like the heads.
Ray
Old 04-10-2013, 12:22 PM
heads
I am in contimplation if i should put them on or not with the low cam gear and the old trans. i have the stock heads that came with the 327 it has a -^- marked on the front of the heads. i dont know the specs yet of eather or knowing how to check for that matter.. any suggestions??
Old 04-10-2013, 12:59 PM
Try this site
Head Guide
It should give you all the information you need for any early small block head. It has diagrams of markings on the heads and what cc and valve size they are, also what years of small block they came out on. I use this chart when I cruise wrecking yards
Hope this helps.
Ray
The Following 2 Users Say Thank You to 69 widetrack For This Useful Post:
64 chevy step (04-10-2013), Richiehd (04-10-2013)
Old 04-10-2013, 02:46 PM
heads
Ok so judging by the diagram that 69 widetrack sent me it says they are 283 powerpacks 59 cc chamber 1.72/1.50 valves. the fuelie heads i have are 1.94/1.50 valves and 64 cc chamber... awsome diagram by the way thanks..
Old 04-10-2013, 07:24 PM
vinniekq2's Avatar
what you call power pack heads also came on 210 hp 327s,at least that pointy triangle casting mark
I think you need to identify the rear gears you currently have and tell us what you want the truck to do? Im not a big fan of what people call "rv" cams as the definition has changed over the years.We now better understand how engines work and breathe so picking a good camshaft is easier than in the voodoo days.
Is the truck 4 wheel drive? a daily driver? recreation only,,,,,
Old 04-11-2013, 07:31 AM
Originally Posted by 69 widetrack View Post
too bad he was talking about a 396, that never came with fuelie heads. Bit of an error on Bruce's part but still a cool song, just like the heads.
Ray
Don't worry; Manfred Mann's Earth Band got even with his faux pas by replacing the lyric "cuttin loose like a deuce" in their cover of his song "Blinded by the Light" with their lyric which sounds a lot like "revved up like a ******." LOL
Old 04-11-2013, 08:42 AM
I also have PowerPAck heads on my 57 Chev 2 Door hardtop, the engine is a 283 4 bbl, dual exhaust rated at 220hp.
Thanks for posting that chart. 69 widetrack
peace
Hog
Old 04-11-2013, 11:18 AM
'64 and '65 "fuelie" heads have 2.02/1.60 valves.
327 heads. bodydroppedsquare Engine 7 08-04-2008 12:45 AM
327 heads John Harry Arnold Introduce Yourself 2 08-21-2007 08:46 PM
327 heads?? 89SDime Engine 4 01-28-2005 07:04 AM
Heads for 327 LoveThemMercs Engine 0 09-19-2002 06:47 PM
Fuely Plugs Moosa427 Engine 4 03-25-2002 08:22 PM
