fule - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2003, 12:47 PM
fule
if you change the fulue sender and chang the fule pump with that add more powere and were is a good place to get new fule lines
Old 09-25-2003, 01:25 PM
New Member
GM dealership
Old 09-25-2003, 01:30 PM
lluciano77's Avatar
It will ony add more power if your current setup doesn't flow enough. 3/8" fuel line should be sufficient, although stock lines are usually 5/16". You could get an aftermarket fuel pump. Just don't get anything more than 100 GPH. I like to use aluminum tubing from the hardware store for my fuel line. I get the 3/8" line and some of the compression connectors and couplings. They are easy to work with and are relatively cheap.
Old 09-25-2003, 01:43 PM
what do you use to bend it with
Old 09-25-2003, 01:45 PM
roys63's Avatar
A Tubing Bender
Old 09-25-2003, 02:00 PM
If your truck came with a 350, you should already have 3/8" fuel lines. Get a 5/16" open-end wrench & see if it will slip over the steel fuel lines on the frame & into the carb. If not, you have a 3/8" line already. My friend's '75 C-10 w/350 & 2-bbl carb has 3/8" line from the factory.
Old 09-25-2003, 02:03 PM
lol i have rubber ones. the only metal ones i have from the pump to the carb
Old 09-25-2003, 02:38 PM
HOTZY57CHEVY's Avatar
I CARRY NO CASH, I'M MARRIED
ITS SPELLED F-U-E-L NOT FULE!!
Old 09-25-2003, 02:48 PM
sorry so i cant spell
Old 09-25-2003, 03:32 PM
4 Jaw Chuck's Avatar
Even with a spell checker? Sorry bud, that is not a valid excuse.
— Han Solo
chevy, fuel pump
