Full MSD system not firing - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-20-2008, 08:11 AM
malc's Avatar
Living At The Speed Of Life
These are the instructions for MSD-8360 also a ready to run distributor.
Take a look and go to page six, "Ready to run distributors do not require an MSD ignition,though they can be used with one".
That is what "70" Cougar has used, that setup.
If we knew his distributor Iīm sure we could sort this.
Edit;
In the instructions for the MSD box the MSD Ford ready to run distributor is not covered just the MSD-8360 for Chevy.
Thought, Chevies go clockwise, Fordīs counterclockwise, maybe ?
  #17 (permalink)
Old 06-20-2008, 09:07 AM
Wiki Edits: 31
generally if you use the white points trigger wire on a magnetic pickup distributor, it won't work. the points trigger wire takes a supplied voltage from the points, of 6-9 volts.. magnetic pickups operate in MV range as they generate the A/C current that is used.
A ready to run distributor would be capable of charging the coil on it's own. so it's output could use the white points trigger in theory but it still makes no sense to do so when the MSD box is going to control the coil
a quick test to see what you really need... unplug the switched ignition 12v source from the distributor.. disconnect the orange from the white wire, crank the motor over and see if you get a reading in MV by testing the orange wire and ground wire with a volt meter.. set to A/C reading. if you do, then you can leave the switched ignition source unplugged. and hook up the magnetic pickup wires to the orange and black wires..
  #18 (permalink)
Old 06-20-2008, 11:36 AM
Irelands child's Avatar
Two things - the MSD colors on the wires are not particularly good on mine - though mine is a small diameter billet, the orange and red might just be connected backwards.
Next - have you tried the distributor without the control box? There is the outside chance that there is a fault inside the dist itself. If it's the 8350 and ready to run - then use the other diagram just for a check. Quite frankly, you've defeated the purpose of the ready to run feature by using the control box - but of course that was your choice
Dave W
Irelands child
  #19 (permalink)
Old 06-20-2008, 02:34 PM
Last journal entry: Headlights added
I would try
http://www.msdignition.com/forum/
  #20 (permalink)
Old 06-20-2008, 02:47 PM
malc's Avatar
Originally Posted by Bart
Dammint I never thought of checking their website out, thanks for the link.
  #21 (permalink)
Old 06-20-2008, 05:36 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Well Irelands child.... i appreciate the help. as far as me and " my choice" i'll suck it up and say if this is indeed the type of distributer that i need not use a msd box with, i didn't know or do enough research. I wasn't told that ready to run means you do not need to run the msd ign. box. I'll double check again with the tech's at msd and find out for sure. All i can say on my part is when i went in to the store i told the parts person " i have a ford ready to run MSD distributer and a MSD blaster 2 coil can you find the MSD ign. box i need to run with this set up" If he didn't catch that i didn't need it, maybe there's a chance i can take it back. but being that i've totally installed it i may be out my $250 or so dollars
  #22 (permalink)
Old 06-20-2008, 07:20 PM
T-bucket23's Avatar
Wiki Edits: 26
The also should be nothing on the the coil except the 2 wires from the MSD box. If you have your tach connected there, remove it. The tach MUST be connected to the lug on the MSD box. The dealer you purchased the items from sold you more than you need. It looks like with the read to run distributor they do triger off the white wire so that is not your issue.
  #23 (permalink)
Old 06-20-2008, 07:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by ceh383
It's strange to me that they would have you use the points trigger wire when that distributor has a magnetic trigger.
You have a "ready to run" distributor and an msd ignition box, I'd return the distributor and get one of THESE.
In a ready to run the output that goes to the coil emulates what a points signal would look like. I am guessing that there is something else connected to the coil.
  #24 (permalink)
Old 06-21-2008, 02:27 AM
Well i stoped in at lordco. and i figured lets track it back to what distributer and go from there. We see the page and says in a bright yellow blerb across a pic of my distributer, " modual inside" .... so i just pulled the thing out and they said bring it back on monday for my money. put the orange back to the + on the coil, and up it started.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Why does a HO Came change the firing order?? Lloyd1wv Engine 9 01-02-2008 03:07 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
