full quarter pannel or a skin/ patch - 69 z28 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2008, 03:30 PM
the dan's Avatar
83 chevy c10 long bed
not sure if i should to a full quarter pannel or a skin, there is rot around the rear wheel wells, but it only goes an inch around the well. should i do a whole pannel therefor eliminating all the rot, or patch in a skin and risking losing the body line perfection?
Old 09-12-2008, 03:47 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
If it's a real 69 z28, do it right
Old 09-12-2008, 04:36 PM
302 Z28's Avatar
I agree, if it's a real Z/28 do it right and replace the entire quarter. For sure there is more rust that you can't see.
Vince
Old 09-12-2008, 06:58 PM
Old Fool's Avatar
Just get rid of the old rust bucket before you spend a ton of money on it. I will be by and pick it and save you the time and money and not even charge you to haul the old rust pile away!
Old 09-12-2008, 08:14 PM
wildthing's Avatar
Last journal entry: 95 % done
my 68 cougar is the same way , everybody i have showed it to said if i have the whole quater panel then replace it all , getting rid of all the rust.
Old 09-12-2008, 11:35 PM
Huckmag's Avatar
Last journal entry: Change of Plans
If you do replace the whole QP, it may be a good idea to replace the outer wheel well at the same time. Chances are good it's in similar shape as your current wheel lip.
Old 09-12-2008, 11:43 PM
Whole QP, that way you will only have to feather in the joint at the c pillar instead of all the way around a patch panel.
Shane
Old 09-13-2008, 01:43 AM
the dan's Avatar
whole quarter pannel it is!, thanks guys for the quick response. yes its a origional z28, getting a resto with minimal modifications, is there a place to start a build thread here? or should i use the one in the lounge?
Old 09-13-2008, 05:17 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
You can start a Project Journal. You could also give us a sneak preview (a pic or 3) now on this thread.
Old 09-13-2008, 05:21 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
I'd only replace the spots that are rusted.
When you replace an entire panel you cannot replicate the conditions of the factory at the seams and pinchwelds.
Thus your pinch welds, spot welds will start to rust over time.
Full quarter replacements should be for collisions or severe rust that threatens the structural stability of the body tub.
A Car and its Parts are only original 1x...something to think about anyway....
Old 09-13-2008, 09:00 AM
Hotrodders.com is the best hotrod site on the net, bar none. But if you want the best Camaro site on the net, start visiting "Team Camaro" at Camaros.net. There is a wealth of info there on Camaros.
Old 09-15-2008, 09:13 PM
the dan's Avatar
thanks for the site, ill be on there a little bit
Quarter Panel Patch Welding Kampr Body - Exterior 2 10-05-2006 07:41 AM
Welding Quarter Panel Patch and Gas Tank cab Body - Exterior 13 07-14-2006 01:33 PM
Quarter Panel Patch Ron M Body - Exterior 2 08-02-2004 08:05 AM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
Best place to order patch pannels for 69 Chevelle? zachscc Body - Exterior 8 01-02-2003 05:44 PM
