Hotrodders Bulletin Board
#1
full size chevy truck cv axle install
can anybody give me any guidence on replacing the axle in the front of my silverado? it unbolts from the diff case on one end. can i just disconnect the tierod and turn the wheel back as far as it will go and pop the other end out?
#2
is it the drivers side ? don't bother, its not coming out. afaik, the whole dif has to come out.
#3
Say again???? Un bolt the bottom shock bolt, remove the shock from the mount, and allow the shock to extend. Undo the 36mm nut on the outside end of the CV shaft, and then the 6 bolts holding it to the stub on the diff. with this done, the plunge joint will be able to compress and slip under the stub. Put a jack under the control arm, and by finagling the height of the arm, the shaft will slide out through the bottom. |
#4
I havent done one in a while,but I think if you remove the sway bar link you can unbolt the axle flange and the outer nut,and remove the axle assembly through the bottom. It would,in some cases probably be easier to undo the shock,sometimes it is hard to remove a sway bar link and save it.
Back to top |
Similar Threads for: "full size chevy truck cv axle install"
| Mustang II IFS Install in 57 Chevy Truck | mestes | Suspension - Brakes - Steering | 5 | 07-11-2004 02:13 PM |
| Small Chevy car wheel to fit Chevy Truck | musky2 | Transmission - Rearend | 4 | 03-16-2004 08:12 AM |
| 69 chevy truck front end change | dragn azz | Suspension - Brakes - Steering | 4 | 07-23-2003 01:16 AM |
| replace wing windows with full size 57 chevy pu | jim shorts | Body - Exterior | 1 | 05-26-2003 02:44 AM |
