Full size to mid size rear swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 03:25 PM
Hi guys,
I was wondering if the rear end from a chevy 1500 would swap with the rear end in my s10. Im looking to get a lower ratio and my brother is offering me the rear end out of his old truck, can they be swapped no problem or do i need to modify it.
Old 06-01-2008, 08:15 PM
If by "swapped" you mean, does it bolt in, not even close. They are completely different trucks. Spring spacing is different, wheel bolt pattern is different, width is different.
Old 06-02-2008, 02:33 PM
what about the gears
Old 06-02-2008, 02:52 PM
7.5" in the S10 vs. 8.5" (or larger, depending) in the full size. Again, not even close.
Take the free axle, sell it, and use the money to buy the right gears.
Old 06-03-2008, 12:41 PM
good idea thanks
rear tire size on elky elcaminodragster General Rodding Tech 0 04-07-2007 03:21 PM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 02:29 AM
Rear diff swap. g_mac13 Transmission - Rearend 9 01-12-2005 11:42 PM
rear end swap 91 camaro rs twisted91 Transmission - Rearend 5 01-10-2005 07:25 PM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 12:43 PM
