Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fully understanding DCR
  #28 (permalink)
Old 01-16-2013, 02:40 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by steeny View Post
I know I said I would not say anymore on this subject but I can't contain myself.
To the guy's that say it is ok to run "pump" gas ( of any grade) on an engine with 13-1 and compensate with a large duration, high overlap cam is good to go then why would one use a better composition of gasoline to run this same engine at the track. If there is no need then why do it.....cause it smells good?
To the guy's that were like me back in the early 70's building hot rods and high compression engines (even over what you could get already from the factory) to cruise the blvd and race out on the lonely road we definitely understood (even before we were off to college for higher learning) the need. Sunoco 260 was our friend!!
To the stubborn crew that does not want to listen to experience?......go ahead and try your combo on the street with the quality of gas these days. Let us all know of your real world experience learned. Bet I know the answer if your feedback is honest!!
To the guy's that do it successfully.....kudo's for the knowledge and understanding that there is more to it than just huge domes, small chambers and wild camshafts!!!!
I don't think any of us are willing to risk good money on a "what-if" of this kind. This was originally a question posed by Vinnie and I chimed in to put my 2 cents worth in. I've never tried the combination and never will. Advancements in the sport are not made by those who sit back and are comfortable with the status quo, they are made by those who buck the system and try different things. Again, like I said though, I'm not foolish enough to try this, it was just an exercise in fantasy land.
You seem to be a level-headed fellow and I appreciate all your input. Thanks.
