fully understanding DCR
Hey guys
I think I know the answer but I thought id ask the guys that will know for sure. Say you had a 13:1 SBC but had a huge cam in it that made your dynamic compression ratio between 8-8.5:1 would it run on pump gas with out detonation. it is to much cylinder pressure that causes detonation right? PS Im not planning on doing this. I just want to fully understand DCR |
Yes, cylinder pressure determines the fuel. Fuel determines the detonation resistance. Using a 355 Chevy built at 13.00:1 SCR combined with an intake closing point of 70 degrees @0.050" tappet lift generates a DCR of 8.45:1 on the KB calc. Here is the cam I used to calculate this.... Crane Mechanical Roller Camshafts 118471 - SummitRacing.com Theoretically, the motor should run on pump gas, but like I said in the beginning, I have no practical experience concerning these numbers. If someone could present a valid argument against the results I have shown above, using science and math to convince me, I would yield to their way of thinking. |
BTW thats techs cam that he uses in his wifes grocery getter. The old wagon has a lenco 5 speed with a Dana rear with 7.50 gears.
Note: its all about the combination, the Lenco perfectly matches his wifes driving as she lets the clutch out very quickly and forgets to use the clutch when she changes gears The station wagon is perfectly matched with enough room for groceries,back doors for easy egress for the grand kids,and he even hung a clothes line on the back to dry the laundry. The 10,000 rpm drowns out the wifes nagging and the grand childrens screaming and other antics on short road trips its all combination combination |
Thanks Vinnie, made me laugh. :thumbup:
Ummmm, that would be girlfriend though, I have no wife. :nono: |
LOL!!! Nice. Ok so what is the maximun DCR a guy can't get away on 91 octane?
11:1 CR is a decent guideline for old technology.You need to express this when telling someone that 11:1 compression wont work with out a different fuel. New car technology(BMW,Ford) have engines that are 11 and 12:1 cr. All they need is mid grade gas or better.Mazda has 14:1 CR in the economy car line.How is that possible? Mazda also uses 14:1 CR in their economy diesel? How is that possible?
We as hot rodders have to adapt to newer technology. |
an example of a crate engine offered in todays market
Horsepower Torque Bore & Stroke Compression Ratio Fuel Requirement 710 @ 6700 RPM 601 @ 5100 RPM 4.185 x 4.000 12.0 to 1 91 - 93 Octane |
The same crate engine seller has many engines at 11:1 CR all for street engines and limited Saturday night specials. I personally like to learn from those builders |
A fool and his money are soon parted. |
Built plenty of em this way> Not for the street! The answer to your question no. Now to answer the question in the terms your thinking of yes and no. It has to do with the SCR and DCR, moreso the realtionship of the 2 terms. The bleed off of SCR by the cam will bring the cyl. pressure down till the design parameters of the overall build come together with the cam being the determining factor in this conversation. Once the cyl. pressuer starts to rise, the engine builds heat and compression, the filling and emptying cycle is reaching designed parameters with RPM rise...better have higher octane in the gas to promote adequate detonation suppression or it will eat itself to death! And if you think just limiting ign. timing will take care of the flame front and travel, it does not work that way!! I could go on and on with theoretical entropy and enthalpy of a heat engine, gas laws, etc... but that is WAY to involved for here. In short...it is all about pressure, flow, engine speed minimums and a controlled burning for an intended application. Just scratching the surface on this subject! Its the meaning to the whole. |
The DCR begins to rise and eventually meet the SCR as rpms increase and the engine approachs 100%+ VE. Above that the bleed off of a large cam doesn't have enough time to affect things as much. Reversion is almost non-existent at that point.
ie, don't go crazy thinking SCR is low enough in a calculator. Real world at high rpms will see a completely different story. Don't forget quench can help or hurt detonation as well. |
Now you can experiment on your wallet all you want with pinging engines.But please for the sake of the rep of the forum,the newbies that come on it for advise,re-frame from your risky behavior advise. I can without doubt tell you that Tech has a good history with hundreds,no thousands of readers.And I have trailing not far behind him involvement in hot rods agree with what he has said. |
| All times are GMT -6. The time now is 04:26 PM. |
