Dual plugging heads is very common in building high compression high performance motors. I have put dual plugs into a Porsche race motor and had a set of dual plug heads on a BMW twin motorcycly for years. The reason for doing so is to shorten the flash channel inside the combustion chamber. Sometimes this is due to using a raised or humped dome piston to raise compression or to channel gasses out after detonation. The dual plugs compensate for the fact that the flash channel is obstructed by a raised piston dome. Dual plugging generally can reduce the tendancy toward pre-detonation and may allow the use of higher compressions or the use of lower grade fuels. I think you would see it more were it not for the complications of having twice as many components inside the ignitions system. I am sure there is more to this than I understand, but I think my answer is in the ballpark.
OK, here is the Ford reason they did it. Emissions-one side is primary, the other is like a redundant deal, much like a long spark of ans msd. High compression they are not. Our chips sell like hotcakes for them.
