funny shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2003, 02:41 PM
big455's Avatar
funny shifting
I have a new TCI th 350 installed behind as 383 stroker. Problem, it takes too long to shift from 1st to 2nd even under very light acceleration. Also after it has shifted into 2nd it will down shift into first at the slightest tap of the gas, It will also do this between 2nd and third. sometimes it will even go back and forth between fisrt and second while cruising. vaccum modulator is hooked directly to the intake behind the carb. shifter is a B&M mega shifter. Kickdown is not hooked up- cable is too short need to get a longer one, but this should'nt cause this kind of problem should it? Any help would be appreciated.
Old 06-30-2003, 03:47 PM
Skylark_77_455's Avatar
I think you may have a shift linkage problem. I believe your shifter is cable operated and the cable is out of adjustment or the cable may be pinched. The jack nut on the linkage hookup at the shift lever may have come loose and allowed a little bit of play in the shifter.
Old 07-01-2003, 01:00 AM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
May wanna check the kickdown cable. You say that its not hooked up because its too short. Check to see how much movement you have on it. Sounds like its may have been pulled and got bound up at WOT position. This may not be the problem but always worth lookin into.
Old 10-20-2003, 05:05 PM
dmorris1200's Avatar
doesn't play well with others
Is your vacuum modulator adjustable? Double check what's already posted, linkage and kickdown.
BUILT FORD TOUGH
Old 10-21-2003, 01:39 AM
lust4speed's Avatar
Shifts on a TH350 are controlled by the "kickdown" cable that you didn't hook up. Just for testing, take the end of the cable and go to the other extreme, and your shifts should now be too short. It's important to not only hook the cable up, but it has to be adjusted properly for the trans to shift correctly.
Old 10-21-2003, 10:35 AM
EBlack36's Avatar
Rebuilt Excitment
I really hate to disagree, but the shift on the 350th is controlled by the vacuum modulator and the kick down cable is to "kick" the transmission into passing gear. The 700r4 and the 200r4 however are controlled for both the up and down shifts by the "TV" cable.
Old 10-21-2003, 11:58 AM
lust4speed's Avatar
Whoops, there are times that I shouldn't stay up so late on the computer. Last night was one of those nights. I was thinking about the 700R4 when I was responding to the 350 question. I blew it!
Old 10-21-2003, 12:01 PM
EBlack36's Avatar
Rebuilt Excitment
No Problem, I have been know to do that myself.
