fur ball on thermostat's - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 06:01 PM
delawarebill's Avatar
just to throw this question out for an opinion.. my '51 ford flat head V8 truck over heated somewhat last wkend.. pulled the stat's out and both stat's were 75% plugged... like someone put a throw away cloth in the cooling sys for some reason and didn't take it out.. looked like a cat fur ball sticking out of it.. but i'm wondering if there might be something inside the cooling area that came apart ????? i can't think of anything but never can tell.. the rad was orig, so i replaced it with a new rad, new stat's, hoses and even pulled one of the water pumps to ck it..
it better not heat up now... my wallet is lighter now...
Old 06-01-2013, 06:14 PM
techinspector1's Avatar
Wiki Edits: 326
I'll bet a fellow could write a best-seller about the stuff that's been pulled from flathead cooling systems.
Old 06-01-2013, 06:29 PM
Banned
did you hear about the 4 pound hair ball in the tiger's belly that just was removed. Ripley's offerd $250 for it, The owner gave it to them ! but you may have a little cash coming from them to make your wallet a little heavier !! HAHA!! Run Cool my fellow hotroder !!
s10 ball joint/ 4runner ball joint stevetankl Suspension - Brakes - Steering 1 06-16-2012 01:59 AM
mini torch on bumpers to stop them from being fur burgers? tech69 Body - Exterior 2 06-11-2011 12:36 AM
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-08-2011 11:19 PM
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 01:39 AM
Do you NEED a thermostat? voodoosurfer Engine 46 11-18-2005 10:03 AM
