furnace hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2007, 10:49 PM
furnace hookup
I was given a lennox propane furnace today for my garage they had it in the basement and used single wall galv venting I need to no if I need to run double wall and can I go straight up thru the roof ceiling is osb along with the roof sheeting any advice appreciated thanks also should I run a trunk line with off shoots or just 1 big vent off of furnace garage is 24x32 but might add another 24x20 in a year or 2 thanks
Old 03-08-2007, 12:32 AM
dinger's Avatar
Get the model number and find out the clearances and type of venting that need to be done. Single wall as in bvent for the old installation? A roof flashing will be needed, you should be able to penetrate obs as long as the proper clearances to combustibles are maintained. Dan
Old 03-08-2007, 12:55 AM
I have a reznor 65,ooo btu, in the overhead, I doubled up the pipe going through the roof, wether I needed to or not, my garage is 24x 24 with a 26x 30 added on the back, so its 1356 sq ft, I just let it blow right out the end, no duct work, I have used it since 1990, and never had to touch it, knock on wood huh.
I can take it up to 78 degrees, thats as hot as I ever went with it, might be more left, but it will heat, its natural gas.
Rob
http://www.1969supersport.com/
Oh, I went through 7/16 aspenite, six inches of insulation, 7/16 aspenite shingles and out.
Old 03-09-2007, 09:01 PM
59 wagon man's Avatar
if you are passing thru any combustable material you should def use double wall or b-vent pipe . you will also need to maintain minimum clearances with b-vent usually an inch or so to combustables
Just Bought a Furnace Need Help with Chimney 69crewcab Garage - Tools 11 11-11-2006 06:16 PM
AWD worth it for better hookup? thisisausername Transmission - Rearend 3 07-19-2005 10:23 AM
need help with carb hookup (trans cable) RodFather Engine 6 11-30-2004 06:35 PM
tach hookup on an 88 camaro 67chevelle502 Engine 4 03-06-2004 01:45 AM
How to hookup passing gear to carb? clayboy Transmission - Rearend 4 09-20-2003 08:38 AM
